How to increase database speed
reltio-coderabbit November 11, 2013
What is wrong with this configuration?
It generates a lot of validation queries.
Also I've tested with testOnBorrow=true, testOnReturn=false, but it doesn't change anything.
<jira-database-config>
<name>defaultDS</name>
  <delegator-name>default</delegator-name>
  <database-type>mssql</database-type>
  <schema-name>jiraschema</schema-name>
  <jdbc-datasource>
    <url>jdbc:jtds:server</url>
    <driver-class>net.sourceforge.jtds.jdbc.Driver</driver-class>
    <username>jira</username>
    <password>jirapassword</password>
    <validation-query>select 1</validation-query>
  </jdbc-datasource>
</jira-database-config>
Renjith Pillai
November 11, 2013
I didn't quite get the question. The validation query is meant to be executed continously to validate the db connectivity. Are you facing any application performance issue?
Sergey Svishchev
February 26, 2014
validation query is meant to protect the app from database restarts, but if the database is reasonably stable, constant validations are somewhat pointless
