I want to integrate AppVeyor to JIRA.
As i can easily integrate JIRA with Bamboo/Jenkins(Using Plugin) in the same way, is there any way( or any plugin using that) i can integrate AppVeyor to JIRA.
There's no add-on I can find for any links with AppVeyor.
You will need to
In the same way when I integrate Jenkins/Bamboo with JIRA, it use to show the build status of Jenkins/Bamboo in JIRA Issues pages.
Similar requirement for AppVeyor to JIRA.
Ok, you'll need to write an add-on to enable that display in JIRA.
