How to integrate JIRA with GravityForm
Bong _Grace_ T_ HUYNH
June 4, 2025
Seamlessly Connect Gravity Forms with JIRA for Smarter Task Management
If your team relies on Gravity Forms for data collection and JIRA for task tracking, the Gravity Forms JIRA Integration Add-on is the perfect bridge between the two. It automatically creates JIRA tasks from form submissions—streamlining your workflow and ensuring nothing slips through the cracks.
What is the JIRA Integration Add-on?
This add-on enables you to connect Gravity Forms directly with JIRA. Admins can configure automated task creation, mapping form fields to key JIRA issue attributes such as summary, description, assignee, and priority. With support for multiple feeds and easy configuration, it’s an essential tool for teams using Gravity Forms to manage bug reports, feature requests, or support tickets.
Key Features:
Automatic JIRA Task Creation – Instantly generate JIRA issues from form submissions to keep your projects up to date.
Multiple Feeds per Form – Set up different feeds to send tasks to specific JIRA projects or issue types.
Field Mapping – Map Gravity Forms fields to JIRA fields including summary, description, due date, assignee, and more.
Conditional Logic – Define when tasks are created based on user input with powerful conditional rules.
Customizable Issue Type – Choose the JIRA issue type (e.g., Bug, Task, Story) for each feed.
Visual Setup – Configure everything using the Gravity Forms UI—no technical expertise needed.
No Coding Required – Easily connect Gravity Forms to JIRA without writing a single line of code.
This add-on brings form data and task tracking together, making your workflow more efficient, accurate, and automated.
To learn more about the Gravity Forms JIRA Integration Add-on and how it can supercharge your task management, visit the product page.
Vronik
July 13, 2025
Hi
Thanks for sharing.
Regards
