Do we have any integrators available to integrate Ivanti and JIRA , The requirement is to create automatic tickets in JIRA from a Landesk ticket, which captures all information in JIRA ticket and also send back the updates and state changes to Landesk ticket.
You can check this one from the marketplace ZigiOps: Integrate Jira with Ivanti | Atlassian Marketplace
Hope this helps!
Cheers
Hello Charlie, are you using this integrator or have you used it is the past ?
I haven't use it, but I know the company that sells the app, we were using the app to integrate with other third-party apps such as Salesforce.
Regards
