Hi Experts
I want to integrate Jira to ServiceNow using SOAP inbound/outbound method ? Kindly assist me what is prerequisites for do the integration in SOAP method.
Thanks in advance.
You can't, because the SOAP method and the XML-RPC API was deprecated in Jira more than a decade ago.
Google 'jira cloud SOAP XML' to learn more.
Or "service now rest" for some ideas about how to do this.
Hi @DINESH KUMAR ,
Thanks for posting your question here!
Unfortunately you can't do it with SOAP as it was deprecated in Jira already. Although you can do a REST Based integration using Webhooks.
Alternatively, you can also try a decentralized bi-directional sync solution like Exalate.
It offers you a Groovy based scripting engine for limitless customization and flexibilty.
I am Dhiren, working as a Solutions Engineer with Exalate.
We do offer a 30-day free trial to evaluate the product.
Thanks, Dhiren
@DINESH KUMAR hi! It's already mentioned in the posts above - unfortunately you cannot use the SOAP anymore. If you're leveraging your options, feel fee to check out the Atlassian Marketplace for alternative solutions (ZigiOps is among those solutions.) Fully no-code, easy to set up and customize, ZigiOps easily executes the Jira ServiceNow integration bi-directionally (+none of your data is stored). The tool comes with a free trial version so you can try it yourself.
Regards, Diana (ZigiOps team)
