How to integrate jira with Subversion
Sukanta Datta December 17, 2012
I am not able to add subversion repositories to JIRA. It gives me an error as follows:
  • svn: E180001: Unable to open an ra_local session to URL svn: E180001: Unable to open repository 'file:///C:/Project LDP' svn: E180001: Unable to open repository 'file:///C:/Project LDP'
I could not figure out what is wrong.
Sukanta Datta March 5, 2014
I was able to change some instructions provided and it did work.
Jaroslaw February 27, 2014
I meant how Sukanta fixed the issue:
I had to restore the subversion repository to make it work (svnadmin dump, svnadmin create, svnadmin load).
Could you please tell me what the trick you did?
Pablo Beltran
February 27, 2014
And do not forget the easiest and most powerful: Subversion ALM
https://marketplace.atlassian.com/plugins/com.kintosoft.jira.subversion-plus
Norman Abramovitz
February 27, 2014
I went to look at the tortoissvn/Jira integration and the first thing I read in the README file was
This project is no longer being maintained on this repo. Feel free to clone and work on it.
The readme file also points you off to use someone's branch, so just be aware of that fact.
Sukanta Datta March 3, 2013
I was able to integrate JIRA with subversion and it works.
Sukanta Datta February 25, 2013
I was able to integrate JIRA and Subversion and it works wonderfully
John Garcia
February 20, 2013
Renjith Pillai
December 29, 2012
Using the JI ??
I am using the JI
