How to integrate jira with serviceNow
JIRA-ServiceNow integration helps the customer service and development teams communicate efficiently, in real time. This, in turn, helps resolve the customer issues faster. A bi-directional integration use case could work something like this:
There is datasheet on OpsHub’s website that will detail out all nuances of Jira-ServiceNow integration.
Hi @chennasreenadh,
You can try to use apps which will allow you to integrate JIRA with ServiceNow. ConnectALL ServiceNow adapter for Jira is one of the apps which allows you to integrate your JIRA with ServiceNow.
You can check the page REST BASED SERVICENOW / JIRA INTEGRATION (POC) for reference also check the community from ServiceNow which talks about Service-Now Jira Rest Integration.
Vijay Ramamurthy
