How to interface to MS Project?
William Skidmore
May 21, 2015
We run MS Project to generate Integrated Master Schedules.  Customer wants us to use JIRA.  How do we interface JIRA to MS Project?
Sergey Gussak
September 20, 2016
Ceptah Bridge does exactly that - it integrates JIRA with MS Project: https://www.ceptah.com/Bridge/Bridge.aspx
Jorge Cota September 7, 2018
I used it, it is great. Totally recommended!
Like Jennifer likes this
Brett Taylor
Hi, Go2Group has an integration between JIRA and MS Project - Microsoft Project
I am not sure if it is shrink wrapped yet, but it is there and working.
You can fill out a form to request a trial at http://www.go2group.com/contact-us/
#go2group
There is also a CCA SSO for their JIRA CAC and PIV cards, see http://www.go2group.com/gsa/client-certificate-authentication/
Midori
May 24, 2015
You could also try the The Connector add-on, which integrates JIRA and MS Project. (Warning: its website looks a little outdated.)
If MS Project can import a CSV file, then you could develop an Excel template for the Better Excel Plugin that exports those exact columns in that exact format what MS Project expects. Then, convert the XLS file to CSV with Excel and import to MS Project.
Boris Berenberg
May 21, 2015
There is no way to integrate the two. Perhaps JIRA Portfolio could meet your needs? https://marketplace.atlassian.com/plugins/com.radiantminds.roadmaps-jira#cloud or there are other add-ons which generate Gantt charts: https://marketplace.atlassian.com/search?application=&category=&cost=&hosting=cloud&marketingLabel=&q=gantt
William Skidmore
May 21, 2015
Boris;
Thanks for the answer – disappointing though it is.
Is it possible to export to a flat file with the needed info, so that can be imported manually into MS Project.
This is for a DoD Customer, and they do not plan to purchase any add-ons, and if we bought it, it would not be a billable expense for us, so Portfolio is a dead end.
Boris Berenberg
May 21, 2015
You could export to Excel: https://confluence.atlassian.com/display/JIRA/Exporting+Search+Results+to+Microsoft+Excel and then import that into Project maybe? I have no idea how Project works though, so I am just guessing here.
Brett Taylor
Hi, Go2Group has an integration between JIRA and MS Project. I am not sure if it is shrink wrapped yet, but it is there and working. You can fill out a form to request a trial at http://www.go2group.com/contact-us/ #go2group
Like K Sri likes this
