How to keep a static list of issues in Jira
Fredrik Spadaro August 16, 2017
I'm trying to create a list of static issues that I'd like my project counterpart to prioritize.
Is it possible to track certain issues in Jira in a static filter?
Fredrik
Aleksandr Zuevich
August 16, 2017
In your case you can also do something like this: when you have your issues filtered, just show only key column to easily select issue keys. And then paste in to the filter.
BTW Nic is right, the labels are intended exactly for it.
Unfortunately I'm not allowed (way of working) to add my own labels to specific issues :(
Fredrik
Nic Brough -Adaptavist-
August 16, 2017
That's a shame, because this is exactly what labels are intended for.
Yes, sort of.
Do you know if there is an easier way to add an issue to the filter than editing the filter itself (by adding key = xxx) for every single issue)?
Fredrik
August 16, 2017
You could label them and search for that.  It's a bit less "static", but does the job.
Warren
August 16, 2017
You need some other identifier which can be used for the query. I have had success adding a specific label or component, then my filter can be labels = MyLabel. As long as an issue has the label, it will show in the filter.
Aleksandr Zuevich
August 16, 2017
Hi Frederik,
do you need a filter like "key in (TEST-25, TEST-24)" ?
