How to keep two JIRA issues' status in sync automatically?
h w
November 12, 2011
I have two JIRA issues from two different projects and I need one issue‘s status automatically changed if the status of the other issue gets changed. I tried to ‘Link issue 1 to issue 2’ and it did not work. Do you know if there is a way to achieve this?
3 votes
Łukasz Krupa
I'm from Deviniti team.
You can use existing solution to synchronize multiple Jira instances like IssueSYNC. It works for:
- cloud
- server
- data center deployments and supports different Jira version 6, 7, 8 and Jira editions
- Core
- Software
- Service Desk.
You setup whole integration via UI and you can let your project administrator's to setup/tune own synchronization for remote Jira connections prepared by sys admin before.
If you have questions, please contact us.
Łukasz
3 votes
Riddhi Shah
April 10, 2019
Hello there,
This is Riddhi from team Exalate.
I would like to let you know that Exalate is made for this. It allows to sync information bi- and uni-directionally between multiple Jira instances. Or separate projects in your local Jira.
It's mega flexible, you can sync all types of information, including comments, attachments and custom fields. You can control what to sync and what not, and much more ....
I hope this answer helps.
André Trommestad
April 10, 2019
Thanks :-) I will look into Exalate to see if it will cover my scenarios better.
Matthias Gaiser _K15t_
@André Trommestad, just to let you know there are multiple apps like Exalate in the marketplace which work in similar ways. If you want to get the whole list, go to the marketplace to search for issue sync apps.
André Trommestad
April 9, 2019
I've use Project automation for this and it works fine for my projects.
You have to add automation for each status change.
ex: WHEN "a linked issue is transitioned" -> IF "Linked issue matches status = "In Progress" AND "Link type matches clones" -> THEN "Transition issue Start Progress"
This works fine when the workflow in the two projects the issues belongs to are the same. If not it will be a bit more work setting up the project automation.
Pinelopi Paraskevopoulou
October 26, 2020
Hello Andre,
I am also looking into that currently and I need to achieve that for issues from 2 projects that are being cloned into a board. I would be very thankful if you would be able to provide some more concrete visual examples.
Dieter
November 12, 2011
I'm not aware of any plugin that can do this. for sure this could be done by an event listener. event listeners can even be implemented in groovy, just look here https://studio.plugins.atlassian.com/wiki/display/GRV/Listeners The event listener would need to check if any of the two issues changed the status. If yes one would have to execute the same transition on the other issue. To detect the status change easily one could define a dedicated event for that and create this one in the workflow. That way you just need to check if this specific event was thrown.
Michelle Benes August 18, 2013
We are looking for the same functionality. Has anyone already implemented a groovy script that does this?
FP June 26, 2017
Please use the add-on "Status-Sync for distributed workflows" for JIRA available on the Atlassian Marketplace to set status of all subtasks, related user stories of Epics or linked issues on one hand or the related parent on the other. You can configure the link direction to determine the target issue(s) as well as the workflow transition to be executed by the first (e.g. start working) or last of the sub tasks (e.g. finished work) or the parent issue (e.g. in case of canceled or postponed).
Florin Manaila
August 18, 2013
You'll need to do some scripting to achieve that, either by using listeners or post-functions. You could use Groovy or JJUPIN or anything that allows you to customize the workflow.
The reason why you won't find that ready-made is because you can have different workflows for the two issues and transitions are the only "legal" way to change the status of an issue. What happens when for issue A you have Status1 -> Status2 -> Status3 and for issue B Status4->Status5. There are a lot of variables in this use case, so it's unlikely that you'll find a solution that will work out of the box.
Renjith Pillai
November 13, 2011
Also a third option (apart from event listeners and command line interface) is to use the SOAP interface of Jira and it is pretty easy to keep the issues status in sync
Renjith Pillai
November 13, 2011
Linking of issues is very useful to establish the relations between issues. This gives traceability of related issues. And the type of links are just for the readablity to clearly indicate what type of relation exists between the issues.
Bob Swift
November 13, 2011
Linking issues is really a different questiion. The concept is very helpful for many installations. You can add your own link types like linking requirements to development issues for instance. Duplicate means that the underlying issue reported is essentially the same and usually a fix for one with fix the other. Normally, you fix one issue and then close the other issue as a duplicate (reason code) and link them with duplicate. Cloners is different. It says that one issue was copied from another issue for some reason like creating additional tasks for someone else or copy work to a new iteration that was not totally complete in an earlier iteration.
Bob Swift
November 12, 2011
For detecting the change, you could either use Dieter's answer or use external automation to query the JIRA change tables. For updating the second JIRA, you can JIRA Command Line Interface progressIssue or similar techniques. I prefer the external automation route as it is more flexible in handling many similar situations including 2-way changes. Using Bamboo (for instance) to run the automation makes it easy to control (to handle outage cases), keep logs for problem determination, and provide notifications.
h w
November 12, 2011
Thank you both for your responses. If we have to do extra work to achieve this, I wonder what kind of 'link functionality' that JIRA 'link issue' can provide us besides information only? One more question regarding the type of link issue, it seems that the 'Associate' and 'Depend' are about the same, 'Duplicate' and 'Clone' are the same? Does anyone find the usage of linked issue is helpful to them and how?
