How to know how many issues has no workflow associated (integrity)?
Begoña Bonet
We need to evaluate how many issues has no flow associated.
Which will be the sql to launch to de DB?
Many thanks
Begoña
Nic Brough -Adaptavist-
May 7, 2015
All issues have workflows associated with them.  If they don't, then you've got quite a broken system.
You probably need to try the integrity checker first.  Not mess with the database.
Begoña Bonet
If I launch the integrity checker.... Will the system performance be punished? That is.... it's better to launch this process this nigth or it doesn't matter...
Begoña Bonet
I don't think in update the broken issues, only launch a select count(*) to know the problem magnitude.
May 7, 2015
It won't load it any more than an SQL query. And the checker reads first and then says "I found X issues, do you want to fix them?"
Begoña Bonet
Ok! Many thanks!
Begoña Bonet
I've launched the checker by I recive "Proxy error" message from server. It must be because of the server/proxy configuration. Is there any other way to know how many issues has been affected?
