How to let updated field(system default) and custom field (date picker) show different time format?
George Chiu March 15, 2019
Hi Jira Community,
I have set a custom field which is date picker and a system default field called updated.  When I want to export these two I found that they all showing time h:mm a.
I notice that on look and feel page I set all the time format = YY/MMM/DD h:mm:a
I have also checked the advance setting which the date picker format is correct.
I want to let updated to display YY/MMM/DD h:mm a and let custom field to display YY/MMM/DD.
Please help. Thanks in advance!
Tarun Sapra
Hello @George Chiu
It seems you are running into this issue
https://jira.atlassian.com/browse/JRASERVER-59791
George Chiu March 17, 2019
Hi Tarun,
Thank you.
Seems like a known issue lasting for 3 years.
