×Hi,
I have a set of Jira IDs downloaded from Jira and saved as an excel document. Is there a way to map those IDs in the excel to actual Jira ID and make columns in excel get automatically updated according to the Jira?
For an example : When the status of ID-1 changed to "Done" status from "In-progress" status, can I make it to automatically updated in the excel as well?
Hansi
In JIRA OOTB this is not possible however there is a plugin (paid) that might help you with that
https://marketplace.atlassian.com/apps/37857/excel-connector-for-jira?hosting=server&tab=overview
I think does exactly what you want to achieve.
Hi Mirek,
Thanks a lot for the support. I will try it :)
Hansi
