×I have JSON code that creates an issue in JIRA when submitted through a Confiform in Confluence.
If the request is a follow-up to a previous request I want the new issue created to be linked to the original issue.
The only code I've found to do this is an update to the record.
Is it possible to create the link at issue creation, or do I need to have a second IFTTT to update the issues after the follow-up issue is created?
This is really a question about Jira REST API and how to link the issues between
https://confluence.atlassian.com/jirakb/how-to-use-rest-api-to-add-issue-links-in-jira-issues-939932271.html should help
(seems to be possible in "one go", at issue creation)
