How to link jira using Relates to on import issues using CSV
Swalah Khamis
January 20, 2021
I am getting the following error and I cant resolve it
please help
2021-01-20 19:39:01,384 WARN - Issue link 'Relates' between 'LTP-155' and 'Relates to' cannot be created - at least one of the issues couldn't be found.
Balavinayagamoorthi
Hi @Swalah Khamis ,
This is not the Error. This is a warning during your Validation,
So your mapping is correct,
If you press import, issue will be created with appropriate linking.
Swalah Khamis
January 20, 2021
Adding the image for the mapping field. There is no issue choice under Issue issueCapture.PNG
