How to link two issues in JIra?
Sana Usman November 11, 2024
I want to link 2 issues, initially, I could do it very easily but suddenly I cannot find the options.
7 votes
Dan Breyen
Hi @Sana Usman welcome to the community.  Below the issue summary, you can have two options, one would be a the "Link Issue" that your used to.  Another option could be that you have an '+Add' below the item summary.  The 'Linked Issue' is now in that "+Add" menu.  Atlassian is trying to clean up the page a bit in the cloud.
Hope that helps.
Thanks Den! your suggestion helped! I found the solution.
Like Humashankar VJ likes this
Robert Wen_Cprime_
@Sana Usman! Welcome to the Atlassian Community!
Can you drop a screenshot of what you're seeing?  I'd like to see what you're seeing.
