How to make a field in Jira issue mandatory ?
Krupa M
July 25, 2022
I need to make due date field in the create issue mandatory
3 votes
Gaurav
Hello @Krupa M
Welcome to the community!!
In order to make any field mandatory, there are 2 options:
  • Make the field required from the Field Configuration
  • Use the workflow validators for the transition. This is natively not possible on the Server/ DC but is available on Cloud. There are plug-ins which provide this functionality for server/ DC
Hope this addresses the query. Kindly accept the answer if this helps.
--GG
Fabio Racobaldo _Catworkx_
Hi @Krupa M ,
welcome to the Atlassian community!
In order to make a field mandatory on creation, you need to setup the related Field Configuration associated to your project/issue type.
Hope this helps,
Fabio
