1. When you want your velocity to point to the 'Projects' in the Top Navigation Bar,
you put like below.
<meta content="atl.jira.proj.config" name="admin.active.section">
2. When you want it to point to the 'Issues', what content key is valid?
Try this:
<meta name="admin.active.tab" content="issue_types"/>
Jobin, thank you for your information.
To be specific, I want it to point to the 'Issues' tab in the non-admin screen, not in the Administration.
I am not sure. Try adding this instead.
<content tag="section">find_link</content>
I tried it but it did not work.
I will find a solution later in the near future.
Thanks, anyway.
@Akira: Jobins answer with <content tag="section">find_link</content> is correct. You have to put it to the <head> of the document.
