×Hi friends , Need your help .
I will start to describe my problem -
My current solution :
My problem -
Is there option that Project will be "familar" with other projects fix versions ?
What can I do ? I am open for new solutions .
My main aim is to enable Project C to manage 1 sprint and ability to control its BKL .
Thanks in advance .
Ideally Project C would have it's own releases (fix version). Otherwise there are a couple of things I could suggest:
Good luck!
