I'm trying to import tickets from a CSV into jira.
My assignee & reporter names are exactly as the users in jira.
How ever, when doing the import, jira creates a new entry for every name in the CSV .
How can I do this mapping correctly?
If they are the same, Jira should not recreate them. Are there any errors/messages in your import-Log?
You can map them manually if you tick the checkbox for manual mapping.
