How to map existing filed to custom field in same screen?
Sreedhar Medikonda
September 27, 2013
Could you please help......
I created custom field 'Release Version' on Screen 1 and 'Target Drop' field already exists on the same Screen 1. Now I want to map the 'Release Version' field with 'Target Drop', so that what ever the values updated for 'Target Drop' should reflect for 'Release Version'. How to map?
With advance thanks,
Sreedhar
Renjith Pillai
September 27, 2013
As I understand you need to update the second field while you are editing the issue. Is that true? In that case, I am guessing Jamie's Behaviour plugin might help - https://marketplace.atlassian.com/plugins/com.onresolve.jira.plugin.Behaviours
Sreedhar Medikonda
October 1, 2013
Thank you Renjith, I installed this plugin and hope this will help to get done my requirement.
RambanamP
September 27, 2013
Using "Copy Value From Other Field" postfunction you can map those two fields
this postfunction is availble on JSU plugin which is free, check this
https://jsutil.atlassian.net/wiki/display/JSUTIL/JIRA+Suite+Utilities+Workflow+Post-Functions
