I am using Kanban Board. when i click on Issue i am getting details of issue in my right hand side Issue detail view window.
But the problem is we want to change the view of the window. Using configuration section i can add additional fields, cant remove existing one. e.g. i want to remove Fix version and add our own custom field.
Other problem is the configure section i am not getting all the fields which i added. only few of them is available.
-Bala
Two things here
1) You can use field configuration to "hide" a system field like fix version. Or remove it from the screens in use in the screens in use in the project - these both are system admin functions, not project admin. I suspect you are looking at the Greenhopper config
2) Greenhopper uses Fix Versions. If you remove it from the project, you'll lose a lot of functionality in Greenhopper. I don't think replacing it with a custom field will get you much of that back
Yeah Nic, i am looking at Greenhopper config.
Okay let keep Fix versions but i am talking about other fields. I have added many custom fields but i can see few of them in GH board config
