×Hi :^)
as a user, i want to modify labels component in the existed issues.
other components could modify by clicking. however especially labels component does not work. how can i do to modify labels component at existed issues ?
Hello @조현(영상) most likely the labels field isn't at the edit screen. Nevertheless if you press the l key on your keyboard or press the . (dot) and then type labels you should be able to edit the field.
Clearly the most friendly option is to have the field in the edit screen
