×Hi All, Currently we are analyzing an approach to move a project and its configuration scheme from one Jira Cloud Instance to another Jira Cloud Instance.
This movement/migration shall not impact the other configs in the destination jira cloud instance. It would be a great help if you can suggest an approach.
Hello @Saravanakumar
In order to migrate a project from one Cloud site to another Cloud site, there are 2 options:
Kindly accept the answer if this helps you. Please feel free to share any additional queries that you may have.
