In order to keep visibility of all attachments at the issue level, is there any postfunction (via script or plugin) that you know that will move a subtask's attachments to the parent?
Whenever a subtask is closed its attachments should be moved to the parent.
Thanks in advance,
Hey Adolfo,
As far as I know, this is not possible within JIRA configuration, you would require to write a custom listener in order to perform such function in JIRA. Similar discussion was done in the following Answers thread:
https://answers.atlassian.com/questions/177901/sub-tasks-show-parent-issues-attachments
I hope that helps.
