-> Easily modify/undo, rebaseline WBS and/or project resources
-> Link Schedule dependencies.
-> Use sub-task and "To do list" levels in WBS
Is there any specific plugin for this?
Dear @Priyanka Ghongade,
If you are still looking at ways to do this, you may want to try out the newly released Move and Organize for Jira app that provides a dynamic view of your Jira projects in a tree hierarchy.
It allows you to visually overview and also edit on-the-fly (create, edit, recursively move, delete et c) issues. Zoom and pan the tree view quickly and smoothly using keyboard shortcuts and mouse drag-n-drop support that enable you to work very efficiently also with larger projects!
Finally, it does not require any customization of your existing Jira projects - it plugs in directly for your users without making any non-standard customizations to the project or its issues.
Feel free to reach out to me directly if you have any questions or would like to provide suggestions!
With best regards,
Erik
Disclosure: I am a representative of the company offering this solution
