×I use the jira.field.resolution.include parameter in the Properties of a workflow transition. How does one control the order/sequence that the value options are displayed? They are displayed by resolution id, regardless how they are entered when setting jira.field.resolution.include
For example, I enter 3,2,1 (Duplicate, Won't Fix, Fixed respectively). They are still displayed in this order, with Fixed as default.
Fixed
Won’t Fixed
Duplicate
Is there a way to affect the order they are displayed and/or set a default value?
The order will always follow the order defined in the Resolution page (Administration » Issues » Resolutions) page (there is a "order" column)
http://jira-address/secure/admin/ViewResolutions.jspa
Hi, this is very helpful. Thank you Matheus.
Hi Team,
How can we re-order the resolution values in Workflow? Without touching Actual order
Venkatesh.
