How to order issue fields?
LK July 23, 2019
Hi to you all,
I want to reorder the issue fields in my program. Unfortunately, when I added a new field to my issues, the were just added to the bottom. But instead I would like to reorganize them in such a way that that is more logical when used by our client.
Capture3.JPGFor example, I would like to move "Anhang" to the bottom and move up "Beschreibung". Would that be possible? It would be really great if you could support me in this.
Best,
Lukas
2 accepted
Josh_Kochelek__Modus_Create
July 23, 2019
@LK To reorder fields on a screen, you must access the Configure Screen dialogue, which allows for a drag-and-drop interface. The can be accessed in two ways:
  1. The screen can be accessed through the specific project's Administration screens. [Project Settings > Screens] (Project Administrators or System Administrators)
  2. It can also be accessed in Jira Settings > Screen, finding the specific screen and selecting configure
Not sure which version you are using, but here's a link to Atlassian's documentation for cloud:
Defining a screen
LK July 23, 2019
Thank you very much,! This solved my problem perfectly.
Alexey Matveev
July 23, 2019
Go to project settings -> screens. Find the create screen for the Epic issue type and drag fields higher or lower (the way you want the fields to be seen).
LK July 23, 2019
Thank you very much! This solved my problem perfectly.
