How to overwrite due date system field using groovy.
Susheela Kushwaha December 4, 2019
I am trying to overwrite issue Due date but the new due date value do not reflect on the issue. Can you please suggest how to over write system fields in JIRA?
if(issuePriority == "Critical"){
issue.setDueDate( new Timestamp((new Date() + 1).time))
There is no error logged by log.error()  but I still see old due date on the issue after running above code. Please help!
Damian Wodzinski
December 4, 2019
So the srcipt runs correctly, but the date is not updated? Tre reindexing the issue:
issueIndexingService.reIndex(Issue issue).
Also I would try to put log error after if, to see if the condition was met:
log.error("Condition passed")
Susheela Kushwaha December 6, 2019
Thanks Damian. Will re-indexing issue each time it is updated, affect the JIRA performance? Will it increase CPU usage?
Damian Wodzinski
December 8, 2019
No, its only one Issue and it is reindexed only once, when script fire it up.
Susheela Kushwaha December 9, 2019
Tried re-indexing. Log shows updated date but the system due date field still holds the old value:
Here is my script:
import java.sql.Timestamp
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.util.ImportUtils
IssueManager issueManager = ComponentAccessor.getIssueManager()
IssueIndexingService issueIndexService = ComponentAccessor.getComponent(IssueIndexingService.class);
MutableIssue issue = event.issue as MutableIssue
def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService)
def iPriority = issue.getPriority().name
if(iPriority == "Critical"){
else if(iPriority == "High"){
issue.setDueDate( new Timestamp((new Date() + 4).time))
log.warn("Reindex issue ${issue.key} ${issue.id}")
issueIndexingService.reIndex(issueManager.getIssueObject(issue.id));
log.error(issue.getPriority().name)
log.error(issue.getDueDate())
Created an issue with Due date = 9 Dec 2019
Here is the log result:
2019-12-09 14:21:45,677 ERROR [runner.AbstractScriptRunner]: Condition passed
2019-12-09 14:21:45,678 WARN [runner.AbstractScriptRunner]: Reindex issue MKT-10 36901
2019-12-09 14:21:45,747 ERROR [runner.AbstractScriptRunner]: High
2019-12-09 14:21:45,747 ERROR [runner.AbstractScriptRunner]: 2019-12-13 14:21:45.678
But, I still see old due date on the ticket.
