I have a dashboard that I've placed issue metrics on to be used as a management status page. I want management to be able to view the Dashboard and post comments or questions that I can respond to. However, the comments feature is not able to be used on a dashboard. I've tried using the Text gadget but anyone entering text has to use HTML and there is no timestamps or names associated with the text entered. I'm considering an add-in like Questions for Confluence, Discussion, Easy Forum or Community Forums, but those are really overkill. Any simpler suggestions, really the comment feature is all that is needed. Thanks.
Yes we have confluence. In fact on one part of the page I already have the confluence gadget that is used to show a page that has the current status report.
Do you have Confluence?
