×Hi,
Thanks in advance.
Text field to be populate when i select the checkbox field with script runner. As i know behaviors not present in cloud script runner. Any one help me, how to achieve this.
Have you considered using the built-in automation rules instead to make this change for the text field? Here is a documentation link if you want to consider it:
Best regards,
Are you noting that you were not aware of the automation functions, or that you cannot find them?
For a Classic Project, you may find automation rules with:
For a NextGen project, you may find them with:
