How to port a Jira project and all its associated dependencies from one jira instance to another?
Murad Khan June 26, 2024
Is there even such a thing and if so, how might it be achieved?
Problem:
We have 2 on prem instances of Jira and would like to lift and shift a Jira project from one instance to another. Assume both instances are identical in terms of their configuration and authentication setups with different access URL.
Pablo Gamblin _ServiceRocket_
Hi @Murad Khan
You are able to do this with third-party apps such as Configuration Manager for Jira.  You can learn more about this app at the following link:
If this is not an option for you, you may be able to follow the instructions in the answer linked below:
Hope I was able to answer your question!
Murad Khan June 29, 2024
Yes, thanks very much for your guidance
SERVER
