How to precise that the trigger issue of automation is an Epic and not any other issue type
Mguiss, Anis (AllianzGI)
Hi All,
I crated an automation rule to automatically create to stories each time a new Epic is created but the problem is that this rule is applied when crate any new issue type not just Epic.Capture.PNG
2 accepted
John Funk
Hi @Mguiss, Anis (AllianzGI)
Do something like below:
John Funk
Hi @Mguiss, Anis (AllianzGI)  - Can you share the final solution you came up with?
Hi @John Funk I just followed your advice and it works!!
Like John Funk likes this
CHINNAMUTHEVISAI.SATYANARAYANASHARMA
Hi
Add a new condition that issuetype is equal to epic after the initial condition.
