If memory serves -- and I could be mistaken -- I thought I once had things set so that when I created a subtask the contents of the parent's description field was placed into the subtask's description field.
I can do that now, but you don't see the field's contents until after the subtask is officially created.
I want to see the field filled in on the initial creation screen.
Any ideas?
Figured out a kudgy way:
Copy subtask 'Description' to temp field.
Copy parent 'Description' -- goes into subtask 'Description'
Copy the (new) subtask 'Description' to the subtask field where you really want it
Copy the temp field back to subtask 'Description'
But all I really want is a way to put various Parent fields on the Subtask screen.
There's now a very easy to configure way to keep fields for parents and sub-tasks in sync using Automation for JIRA!
You can easily modify related issues (such as parents, stories, sub-tasks, epics, linked issues and even JQL) using our related issues action and condition:
(this example updates the description, but pretty much any field can be edited)
For more details see https://blog.codebarrel.io/synchronize-parent-and-sub-task-issues-with-automation-for-jira-bdcca6c9d453
You can use post function "Set Field Value from parent" on the create step, but I don't think it's possible to see the copied value on the create screen itself - because this is a post-function it's not going to occur until you've completed the step. I'm not sure how you would have configured it previously to display on the create screen?
No. Other way around.
I want the text in the parent's 'Description' field to be written into the subtask's 'Description' field on the screen when the user first sees the subtask.
I can already copy the text to the field with a post task, but not until the subtask is saved the first time. I want the text in the field the first time the user sees it so s/he can edit the text as appropriate for the subtask.
The best I can do is to take the description off the screen and thus force the user to create the subtask and then re-open it for editing ... which is too much trouble for the user.
Hi George,
If I understood correctly, you want to have subtask custom field display in your parent issue?
