In Jira, when using bullets in the description field (or any other wiki rendered field) the following line is also indented. Is there anyway to remove this? If I'm speccing out the field requirements then I want to only use bullets to show multiple options within a list.
e.g.
field A length = 40 char
functionality for field A
* scenario 1 = Customer
* scenario 2 = User
functionality for field B (I DON'T WANT THIS INDENTED)
* scenario 1 = Email
* scenario 2 = Username
next line (I DON'T WANT THIS INDENTED)
I know I could make the entire thing a list but it makes it harder to read and when you do need a few layers of bullets you run out of horizontal screen space pretty quickly. Adding a line space in between isn't ideal as the content should all be together and also makes it even trickier to update and see what you're doing in edit mode.
Hi Meg,
I can reproduce the problem you're seeing.
The good news is that there is a new Description field coming very soon that will fix this problem. I can't say when it will arrive on your instance but fingers crossed it will be soon.
I hope that helps!
Could you please tell me why this answer is the accepted answer? The problem is still there: the indent is "written in stone" in the middle of a list, with or without a bullet; the new line disrupts both the list enumeration and the wholeness of the given part of the text.
agree, still there
Double enter works but then you have a line break where you don't want one. I'll get a screen shot for you. Thanks for looking into this!
Yes that's what I do. The issue is that after that it still indents (even though there is no bullet icon showing)
Doh!
Would you mind attaching some screenshots of what you're seeing? That will help me find the right team to ask.
Also, what happens if you do a double enter? ie. enter an additional newline
Thanks Meg.
Would you mind adding one more screenshot zoomed out a little bit so I can get some context on your jira instance? I'd like to see which screen you are on
Hi Meg,
what happens if you move your cursor to the end of the line '* scenario 2 = User' and then hit enter?
Also which version of Jira are you using?
Thanks Meg,
and can you delete that * after it get automatically added?
