How to prevent user create more than X issues?
mkocman
September 5, 2018
Hi All,
is any possibility to prevent user create more than X issues?
I need account for automation and I need to prevent creation of hundreds of issues/tickets from this user/automation.
Do You have any idea how to do this, some Add-ons?
Thank You.
2 accepted
Nic Brough -Adaptavist-
September 8, 2018
You will need some code, so I'd recommend installing one of the scripting add-ons that allow you to write code in the right place without having to create your own add-ons.
Your code should be a simple validator, which runs a search for "reporter = X" and returns a fail if the number is greater than your limit.
Mohamed Benziane
Hi, i think is not possible in the jira, may be by coding some script or use jira api, for me there is no addon wich limit this.
