×Priorities and dependencies are easily set at the level of an 'issue'...'tasks', etc. Is there a way to do this at the component level?
Priorities can not be set at component level. But there is an small hack which I use to prioritize based on components. What you can do is to create "swim-lanes" in your scrum/kanban boards, these swim-lanes will be based on components and then you can arrange the swim-lanes based on your component's priority, example- The component with higher priority would have it's corresponding swim-lane on the board above the swimlanes of other components and so on.
@Tarun Sapra, how did you create these "swimlanes" in the board? I can only do mine based on status and can't figure out how to do it based on component - but i've seen this hack mentioned in a few diff places.
Hello @Monica Ross
You can create swimlanes in the board by using JQL queries, here's the docs
https://confluence.atlassian.com/jirasoftwarecloud/configuring-swimlanes-764478010.html
Each lane can be based on the JQL query which in turn consists of something like "component = <name>"
No, components are just "parts of a project". Priority is set on issues.
However, having different parts of an issue with different priorities is possible - create sub-tasks. I've automated this in a few places too, by scripting the creation of subtasks based on one-per-component when an issue goes from "new" to "in progress" for example.
Thanks for the prompt feedback Tarun/Nic! I like both answers. But, for my purposes I think I found something easier. Since I'm really just trying to indicate which component(s) will be worked on in what order relative to the others... I can just create inter-component dependencies to imply priority like this:
Component_2 (Initial Task) has FS dependency on Component_1 (Final Task)
