×Hi, I need to provide statistics/reports for a particular project. This should only be provided for a particular project, as it is very specific and we don't want to spoil the other hundreds of our JIRA projects. Also, simple JQL won't last here since I need to do additional stuff like grouping, counting, etc.
There are two approaches that came to my mind:
I would prefer a custom build solution over a paid one
Hello Matthias,
Since you have ruled out JQL, which is used for reporting, thus my suggestion to you is to try out this plugin and see if it meets your requirment. - https://marketplace.atlassian.com/plugins/com.arsenalesystems.dataplane/server/
Also, can you share a specific report requirement, may be then I can suggest something more.
Hi, thanks for the hint. Does this plugin support reports that only can be executed within a particular project?
