I am trying to setup a listener using Script Runner to auto transition a field based on the value of a custom field. The plugin provides the following template:
cfValues['SomeCustomField'] == 'Some Value'
I have tried the following:
cfValues['Field Name'] == 'Yes'
But this isn't working. Any suggestions on how to check the value of a custom field for my condition statement?
Turns out i was making a noobish mistake. This worked for me:
cfValues['Standard Request']?.getValue() == 'Yes'
I needed to add the getValue method in order to do my comparison.
The key question as Thomas says is "what kind of field". You can do
log.warn cfValues['Standard Request']
That will give you the class name, from that you can read the javadoc to see how to get the string value or values, or whatever.
This is not working for me when using Select List, as opposed to Radio Buttons. Any ideas?
Can you post what you are using.
cfValues[
'A Radio Field'
]?.getValue() ==
'Yes'
should work fine.
I am using:
cfValues[‘A Select List Field’]?.getValue() == ‘Yes’
Any ideas why this wouldn't work for a select list?
It should work fine. Use an assertion to test as per https://jamieechlin.atlassian.net/wiki/display/GRV/Built-In+Scripts#Built-InScripts-PowerAssertions
I guess 'Yes' needed to be written "Yes" or the condition kept failing.
I got this working after reviewing your link. Thanks so much!
Is there a parameter I can add to make the condition specific to a project?
&& issue.projectObject.key == "ABC"
I can't seem to get this to work. Tried using an assertion and it returns 404 page
issue.projectObject.key != "ABC" && cfValues['Customization Issue']?.getValue() == "Yes"
This script accomplishes what I want it to do when the value = Yes. But, when the custom field = No, it also firing the function, when I don't want it to.
Any ideas?
Nevermind. Got it figured out thanks to this thread: https://answers.atlassian.com/questions/70196/how-to-set-complex-validators-in-jira-s-workflow
What kind of custom field is this?
If it is a checkbox you could use:
cfValues['Field Name'] != null
Hope this helps,
Thomas
It's a radio button with "Yes" or "No" as options.
Answer o Yes o No ............. it was an example of the radio button field I have with the values which can be chosen.
Ok, but how do you get the value ? cfValue['Answer'].value ?
Answer o Yes o No
Because, in Jira, I would like then test cfValue['Answer'].value == 'Yes' in order to fasttrack a transition, but it does not work unfortunately...
It should be cfValues (plural)
Use: cfValue['Answer']?.value
Use Admin -> Built-in Scripts -> Condition Tester to make sure that is evaluating to what you expect...
> Answer o Yes o No
I didn't understand this...
Did you get an answer for radio button ? I'm still looking for...
Any help appreciated
The accepted answer is correct for radio buttons.
