I want to parse the Excel file, extract the data, and enter it in the custom field.
So I want to read the excel file with filestream first and parse a specific column to get the data, is this possible with scriptrunner?
If possible, please let me know the sample code of which api to use.
Hi @Kim Yu Jin ,
Did you find a way to do this ?
I have a similar requirement to read an EXCEL attachment in an issue and display only one column data in a custom field.
-Abrar
Thank you :)
Hi @Kim Yu Jin ,
-Abrar
