How to read xml output data in Jira
Omprakash Thamsetty
January 11, 2019
Hi, I am calling WebService using httpbuilder but unable to read the output data.
Jira server version 7.7.2
I tried using httpbuilder and getting the results. But How I can read the each field values, which are getting response in text/xml format. Please see below code.
import groovyx.net.http.*
import static groovyx.net.http.ContentType.*
import static groovyx.net.http.Method.*
import groovyx.net.http.HTTPBuilder
import groovy.xml.*
import groovy.util.XmlParser
import groovy.util.XmlSlurper
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.json.JsonBuilder
import groovy.transform.BaseScript
import groovyx.net.http.ContentType
import groovyx.net.http.Method
import com.atlassian.jira.event.issue.AbstractIssueEventListener
import com.atlassian.jira.event.issue.IssueEvent
import groovy.sql.Sql
import java.sql.Connection
import java.sql.Timestamp
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import org.apache.log4j.Category
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
// Set the logging level to DEBUG
log.setLevel(org.apache.log4j.Level.DEBUG);
//def String WSDL_URL = "http://URL-links"
def http = new HTTPBuilder( 'http://url-links' )
String soapEnvelope =  """<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ser="http://service.ws.pcr.pts.com/">
   <soapenv:Header/>
   <soapenv:Body>
      <ser:prDetails>
         <arg0>
            <PRNumber>12345</PRNumber>
            <systemPassword>USERPWD</systemPassword>
            <systemUserID>USERNAME</systemUserID>
         </arg0>
      </ser:prDetails>
   </soapenv:Body>
</soapenv:Envelope>"""
      http.request( POST ) {
          headers."Content-Type" = "txt/xml"
             headers."Accept" = "application/soap+xml; charset=utf-8"
             headers."SOAPAction" = "getDetails"
           requestContentType = ContentType.XML
          body=soapEnvelope
            response.success = { resp, xml ->
                       log.debug "${xml}"
               //THIS ONE NOT WORKING
                //def xmlOutput = new XmlParser().parseText(xml)
                //def casenumber = resp.children().find({it.name()=="caseNumber"})?.text()
                //log.debug ""${casenumber}""
                 //log.debug " case number ${xmlOutput.caseNumber.toString()}"
            response.failure = { resp, xml ->
                log.debug "fail"
Szymon Hubar August 3, 2022
Hi, maybe it will be useful to someone. The code gets the xml with the calendar for SLA PowerBox.
import java.util.ArrayList
import groovy.xml.*
ArrayList regulaDays = []
def remote = new HTTPBuilder("https://jira-test.test")
def issueJson = remote.request(Method.GET) { req ->
uri.path = "/rest/coresoft-calendar/latest/transfer/export/1"
headers.'Authorization' = "Basic api_token" //Change api_token - build string user:password and encode to BASE64
// log.warn("${xml}")
def xmlBody = new XmlSlurper().parseText("${xml}")
def regularWeekDays = xmlBody.calendar.regularWeekDaysCalendar.entries.stringDate
regularWeekDays.each{
regulaDays.add(it)
log.warn(regulaDays)
