I have a web panel displayed on jira issue details view page.
The content of this web panel should be refreshed after a click on a submit button (that also exist on same webpanel section).
The content is generated using a velocity template that get data from a ContextMap provider.
Currently, I use a location.load() after a click on submit button, but we need only refresh the webpanel component not reload the issue view page to get the new data.
web panel declaration:
<!-- Panel to display data from external app -->
<web-panel name="Test"
i18n-name-key="data-panel.name" key="data-panel"
location="atl.jira.view.issue.left.context" weight="200">
<description key="data-panel.description">The Issue View Data Panel</description>
<context-provider class="com.plugin.provider.ContextProvider"/>
<resource name="view" type="velocity"
location="/templates/webpanel-module/data-panel.vm" />
<supports-ajax-load>true</supports-ajax-load>
</web-panel>
data-panel.vm file:
<div id="content-attach" style="display:none;">
<form class="aui" action="">
<div class="input-group">
<input type="text"
class="controls-input" id="inputUrl"/>
<input class="aui-button aui-button-primary attach-button" id="submit-form" type="submit" value="Attach Data"/>
</div>
</form>
</div>
<div id="content-results">
</div>
issue-view-controller.js :
AJS.$(function(){
AJS.$("#submit-form").click(function(e){
e.preventDefault();
AJS.$.ajax({
url: AJS.params.baseURL+'/rest/testforjira/1.0/config/object/issue/link',
type: 'PUT',
contentType: 'application/json',
data: JSON.stringify(dataInput),
processData: false,
success: function() {
AJS.$("#content-attach").hide();
// refresh web-panel data
location.reload();
AJS.$("#content-results").show();
showSuccessFlag('Object is linked to Jira issue.');
error: function() {
AJS.$("#content-attach").show();
AJS.$("#content-results").hide();
showErrorFlag('Failed to link Object to jira issue.');
I know this is an old question, but in case someone needs it.
You can replace location.reload() by:
JIRA.trigger(JIRA.Events.REFRESH_ISSUE_PAGE, [JIRA.Issue.getIssueId()]);
@Nhac Tat Nguyen Can you help me with finding docs for various JIRA methods available?
@ak5123 As far as I know, there are no documents about those methods, but you can use the browser dev tool to inspect the available methods and try them.
Just print the JIRA or JIRA.Events
