How to remove issues from done column after release
sebastian_scondoo October 27, 2013
My done column still displays a lot of issues after releasing. How do I get it empty?
I checked if these issues do have a fixVersion attached. Where do I see the versions that are released? Where do I check the filter for the column?
3 votes
Christian Czaia [Decadis AG]
October 27, 2013
Your board is based on a filter. Add sth like.
AND fixVersion IN unreleasedVersions()
and you won't see those issues after releasing a version.
Ah understand it. The problem was, that I do not released any version yet. Just created new release version by clicking on the link above done column.
but badly as long as there is no bamboo used you cannot release a version in JIRA agile...
Like francisco.rios likes this
October 27, 2013
Yes you can, in the project admin section in JIRA under the versions tab you can manually release versions...
Matt Stokosa
August 2, 2019
Thanks! This worked for me and that column was driving me crazy.
sebastian_scondoo October 28, 2013
thanks, but both versions that I created are only able to be "unrelease", so I am guessing they are released. But if I add fixVersion IN unreleasedVersions() the "done" issues are showing up again
