How to remove priority system field for specific issue type for a project
Sushmitha Bajjuri November 5, 2022
  We are using jira software 8.20.8 version. We have around 120 projects in our jira.
So for one project and specific issue type i do not need the priority (system field). I removed from all the screens, but it does not work. After removing from the screen i am not able to see the field while creating the issue. But unfortunately it's coming priority as medium after creation of the issue and it's not editable.
As I was searching i found few solutions, but does not suite our jira.
1. I can't hide the priority field because it's used by multiple projects.
2. We can't use script runner plugin as it costs.
3 votes
Fabian Lim
Hi @Sushmitha Bajjuri
Hide it using the field configurations: https://support.atlassian.com/jira-cloud-administration/docs/change-a-field-configuration/
But make sure you create a new field configuration scheme for the project. An example here: https://youtu.be/C3Lb1T4liGw
Sushmitha Bajjuri November 6, 2022
Hi @Fabian Lim ,
    We are having multiple projects in jira, all the projects use the priority filed. So I can't hide it for one project.
