×Hi,
I cannot find how to re-open a closed issue, which I know should be possible.
My workflow closed status has the following:
jira.issue.editable true
In the list of issue statuses and under closed is:
The issue is considered finished, the resolution is correct. Issues which are closed can be reopened.
Yet no-where can I find the option allowing me to re-open a closed issue.
I would greatly appreciate any help on this.
Kieron
Hi Kieron,
you can't add transition to a step that doesn't contain any transition (for the active workflow). In order to do that foillow these simple steps :
- Copy your current active workflow
- Edit the just copied wf just adding a new outgoing transition into your closed status
- Replace the old workflow with the updated one
This should resolve your issue.
Fabio
How do I do this? Is there a step by step process?
Hi Fabio,
Tell step by step process. U should know whether others understand ur content or not.
Hi Fabio and Svante,
Thanks I'll try that out - sounds like a bit of a long winded solution though, is that some kind of bug within Jira as I can play around with any other kind of transitions in an active workflow?
Thanks for your help, I'll post back with the result.
Kieron
No Bug, just a limitation. See :
https://confluence.atlassian.com/display/JIRAKB/Cannot+Add+Transitions+or+Delete+Steps+in+Draft+Workflows
Yep, just the way it is actually. Hopefully this will be managed better in future versions.
// Svante
Jus a limitation. The suggested approach should work fine.
Let me know.
Fabio
Hi Thomas,
"jira.issue.editable=true" has nothing to do with transitions between statuses. It's only for editing the fields in a specifc status.
Are you sure you have a tranisition from Closed to Open?
Best regards
Christoffer
In our case the closed issue implicitly applied editable= false, which blocked any further action and ultimately we couldn't complete nor delete sprints.
This article helped resolving the key issue: https://confluence.atlassian.com/jirakb/how-do-i-edit-closed-issues-779160787.html
(Just don't forget to publish workflow as well - I have checked and in edit mode the property was gone, but in view mode it was still there)
Use Status 'Closed' instead of 'Done'.
Closed will allow you to re-open items and create transition from Closed --> Open
Thanks to Fabio and Svante for the solution, it worked perfectly.
Kieron
Hi Kieron,
please, could you check if some condition has been defined in your "Re-open" transition? I think that there's some condition y=that doesn't allow to perform this operation.
Hope this helps.
Fabio
Hi Udo & Christoffer,
No there is no transition from closed to open and I cannot add any as it says there are 'no outgoing transitions in the active workflow' so I can't add any in the draft workflow.
Frankly that means nothing to me, so I don't know how to resolve it.
Many thanks,
Kieron
You would need to add an outgoing transition from Closed to Open in your workflow. If there is no transition between those Steps(Statuses) you won't be able to "Reopen" your issue.
Do you have a transition from Closed to Open in you workflow? If yes, please check your conditions in that transition.
