How to report a flagged issue comment in JIRA using eazyBI
Derek Huether
August 25, 2019
When a user flags and issue, they are given the choice to add a comment. How can I report those comments and only those comments?
Lauma Cīrule
September 5, 2019
Hi Derek,
By default, eazyBI does not import comment information, including Flagged comments.
Is there some way you can tell these comments apart from other comments?
What would you like to analyze - count of the comments or import the whole comment text?
I imagine it would be possible to extract some of this information in Scripted field in Jira and then import to eazyBI as an additional custom field, see https://docs.eazybi.com/eazybijira/data-import/custom-fields/advanced-settings-for-custom-fields.
Lauma / support@eazybi.com
