×I want both of my instances to have the same comment ID
I would not do it if you are talking to 2 prod instance, if it's prod and test instance,, restauring prod data to test instance will make them have the same ids.
Comment id are generated by JIRA, if a comment is created in one of the instance but the other they will then mismatch.
What is the requirement behind this request ?
Regards
Hi @Florian Bonniec
I get the answer now.
I have 2 instances, Prod and Test, which
will do the backup and restore to get the same ids.
I need to Sync the issue and comment between 2 instances.
