Problem with integration of Jira Server v7.12.1 with "Slack for Jira Server" plugin v2.0.6
Versions used :
Our Slack instance is already integrated with a jira instance, and I'm trying to integrate our slack workspace with a second jira instance.
It seems doable but for this to work we need to configure a custom Slack application, and follow the documentation at https://confluence.atlassian.com/slack/using-jira-applications-with-slack-966662163.html#UsingJiraapplicationswithSlack-IusemultipleJiraServerinstancesormyinstancesarebehindafirewall.HowdoIconnectthemtoSlack?
While configuring this application, I noticed some issues not covered by the documentation :
I need to grant scopes, those ones :
However, two issues :
For now I've granted the following scopes :
when trying to connect Jira to Slack from the https://<JIRA_HOST>/plugins/servlet/slack/configure page, I get an issue about wrong credentials, while the jira server log throws the following message :
/rest/slack/latest/connection [c.a.p.slack.util.ResponseMapper] Slack returned an unsuccessful response to users.info/UUSKXMPN3: missing_scope
Where UUSKXMPN3 matches the application itself.
What am I missing ?
Thanks for you help
We had the same issue.
We overread on https://confluence.atlassian.com/slack/using-jira-applications-with-slack-966662163.html to use the classic scopes.
To get started, first visit https://api.slack.com/apps?new_classic_app=1. Make sure you create the App with classic scopes as Slack has released a new permission model that's not compatible with this App at this moment.
After that it worked.
Thank you a lot ! I've indeed overread the documentation (but let's be honest, the documentation is also outdated, as we also have to configure a legacy bot) It helped. I still have another issue, but at least I get the integration almost working.
For now I'm stuck with "limited connection issues" showing in Jira, despite my jira instance is accessible. I'll see if someone else already had the same problem
Slack cannot connect to your Jira server - it may be behind a firewall.
You can still receive messages from Jira in Slack, but some functionality (such as slash command or Issue Preview) may not work.
Thanks again
~ Morgan Wattiez
