How to restrict edit issue in status for reporter?
Chasovskikh Kirill
I need to restrict edit issues in status Open for reporter.
Based on this article i'm trying to use properties in any configuration
jira.permission.edit.reporter = false
jira.permission.edit.reporter = denied
but this properties don't work
i'm trying to use workaround and restrict edit issues for all users except one user, using
jira.permission.edit.user = userid
but this properties also doesn't work
where I have a mistake?
Becky
Hey @Chasovskikh Kirill
The article you provided pertains to Server Products and is not applicable to the Cloud version, here is the article that you need.
To prevent reporters from editing issues in Open status, you can use the following configuration settings:
Property Key: jira.permission.edit.denied
Property Value: reporter
I hope this helps you. Please let me know if you have succeeded. :D
Chasovskikh Kirill
thanks a lot!
Like Becky likes this
Yash Pradhan
Hi Becky,
Can you help me ?
How to revoke these changes can you help me,
I need the solution for this asap!!!
Becky
@Yash Hi,
Just delete the property and save the new workflow.
