How to retrieve data from Multi-Select field and use it as String?
Mateus Oliveira September 27, 2023
I'm trying to make an automation to replace my Summary with the values selected in a multi-select field, but I can't discover how to retrieve the data from a multi-select field and convert it to/use it as string to populate my Summary field.
Ralf Fehling
September 27, 2023
Mateus Oliveira October 20, 2023
Thank you! I thought I'd have to compile the array of values, but it takes care of it automatically...
